MIDI Note Off?
MIDI Note Off?
Is it possible to have SCS take an action on a Note On (such as run a cue) and take a different action on note off?
Re: MIDI Note Off?
Yes you can set this up in Editor > Production > Production Properties > Devices > Cue Control
http://www.showcuesystems.com/scs11help ... ontext=390
Re: MIDI Note Off?
Yes. I've got it working for note on. I want to do is when I receive a note on message, I stop playing a track. When note off comes in, to start. Same note. I'm trying to trigger an effect when I cut a mic on the sound board, and resume it when I re-open the mic. The analog console I'm using sends Note On when a channel is unmuted, and Note off when it is muted. I'm currently playing around with MIDI Ox to try to massage the incoming MIDI into what I need.
Re: MIDI Note Off?
In Production Properties / Devices / Cue Control, for your MIDI device try this: Set the 'Control Method' to 'Custom'. You can now select 'Note Off' as the MIDI command for a selected Cue Control Command.
