SCS 11.6.2 Available
Posted: Tue Jun 13, 2017 3:54 pm
Registered users with current update plans (including users who purchased or upgraded their SCS license during the last 12 months) may now download SCS 11.6.2 from the Download page of the Member Area. Note that as this a bug-fix release, the 'release date' has been backdated to that of 11.6.1.
You can optionally download an SCS setup file that includes the installer for LAVFilters (included with permission). If you do not already have the latest LAVFilters installed then we strongly recommend using the download with LAVFilters if you want to play any video file cues.
New and Changed Features in SCS 11.6.2
SCSremote is an application to remotely control SCS with an Android Smartphone or tablet. SCSremote can control basic SCS functions such as playing cues, navigating between cues, adjusting master level, and displaying cue times and progress. It is available to download from Google Play. SCSremote has been developed by Simone Guisti and any queries on this should be directed to simone@rockopera.it
Some SCS features may not be available in all license levels. Please check the 'Feature Comparison' section of the Help for details.
- Change to registration process to allow SCS registration available for all Windows' users.
- The currently-selected audio driver (DirectSound or ASIO) is displayed in the VU meters area for 5 seconds when the driver is selected or changed.
- Fixed an error in 11.6.1 that prevented images from being resized.
- Fixed an error in 11.6.1 that prevented network input messages being processed (apart from PJLink and PJNet messages).
- Fixed an error in 11.6.1 regarding PJNet connections.
- A looping cue may fail to loop if the BASS Mixer is not selected.
- Using Shift+F11/F12 (or similar) to decrease/increase levels of playing cues would cause incorrect levels to be set if applied during a cross-fade of a looping cue.
- SCS could throw a subscript error when adding or removing certain device types.
- Fixed an issue regarding the stopping of MTC sub-cues when linked to a sub-cue that is stopped in the editor but when the cue itself was started in the main window.
- A memory error could occur if you have a disabled video/image cue that uses a screen number greater than any screen number of enabled video/image cues. For example, if one cue (only) uses screen 3 but that cue is disabled, and all other video/image cues use screen 2.
- MIDI Control Send cues would not send MIDI messages through a port that was also used for playing MIDI files.
- Removed the delay incurred when using 'stop all'. The delay had been added in 11.6.1 for 'fade all' to ensure the fade out time had completed, and should not have been applied for 'stop all'.
