OK ... so I'm stupid ... or maybe not
Posted: Tue Apr 25, 2017 3:42 am
I have SCS11 Lite and am struggling with something that I thought should be easy. I need to set up 4 audio tracks that loop sequentially and continuously until stopped with a SFR cue. I've found the section in help:
However, whatever I do, and following the instructions seemingly to the letter, when I run test, it only ever loops though the first of the four tracks and never drops through to the later tracks. What am I doing wrong please?Loop Linked: Audio File Cues with linked sub-cues may include a loop. The loop (if required) must be specified in the first of the Audio File sub-cues, and the loop may then also be automatically applied to the linked sub-cues. This Loop Linked checkbox is provided to indicate that any linked sub-cues are to have the loop applied to those sub-cues as well. Do NOT enter the loop details into the linked sub-cues or SCS will break the 'link'. Note that the Loop Linked property only loops correctly if the BASS mixer is used (or you use ASIO instead of DirectSound). SCS automatically switches (if necessary) to using the BASS mixer if when loading a cue file it finds one or more cues using the Loop Linked property.
