SCS 11.5.2.4 Available
Posted: Thu Dec 01, 2016 11:25 am
Registered users with current update plans (including users who purchased or upgraded their SCS license during the last 12 months *) may now download SCS 11.5.2.4 from the Download page of the Member Area.
* This is a bug-fix version only so the download eligibility date has been backdated to the release date of 11.5.0 (28 June 2016). If 11.5.2.4 is not available on your download page, try the download archive.
Bugs fixed in SCS 11.5.2.4
- If you choose to hide tooltips (in Display Options) then all SCS tooltips are hidden. Previously this test was not applied in a few cases, such as the tooltip display of cue list items that are wider than the displayed field width.
- The Visual Warning 'countdown whole cue' was not being displayed for, say, an audio file cue, if an image cue set to 'continuous' was currently also being displayed.
- Fixed an error regarding located files (ie files selected via the 'locate files' window) losing their fade-in and fade-out times.
- Fixed an error that prevented dummy devices being recognized if you change the language (in General Options).
- Fixed an error in 11.5.2.3 whereby short fade-out times on an audio file cue could initially fade quickly (as specified) but then hold the partially fade-out level for about half a second before completing the fade-out.
- With some mono audio files, playing the mono file to an audio output device assigned to a single output (speaker), the audio could switch from the left speaker to the right speaker or back again about every two seconds. This has only been found with a very few selected mono files, of various formats, and only occurred when the audio driver was DirectSound and if the BASS Mixer was not selected. An updated version of the BASS audio library corrected this bug.
- When using the Copy, Move, or Delete a Range of Cues dialog, after selecting "View Changes" it was not possible to scroll through the list, which may be required if the list is longer than the display area.
