SCS 11.5.2.2 Available
Posted: Mon Sep 19, 2016 11:19 am
Registered users with current update plans (including users who purchased or upgraded their SCS license during the last 12 months) may now download SCS 11.5.2.2 from the Members' Download page.
New and Changed Features in SCS 11.5.2
  • Multiple Hotkey Banks are now available. The first bank is labeled 0 and is common, ie hotkey cues for bank 0 are always available. Other hotkey banks (labeled 1-12 or less, depending on your license level) are mutually exclusive. For example, you can have hotkey A in banks 1, 3 and 6, and they can have different assignments in each of these banks. Only one hotkey bank is 'selected' at any time, apart from bank 0 which is always 'selected'.
  • Lighting Cues may now include comments in individual DMX Item lines.
  • Lighting Cues with a cue activation method of hotkey 'note' or 'toggle' now blackout the designated DMX channels when the hotkey is released (for 'note' hotkey) or the cue is activated whilst currently playing (for 'toggle' hotkeys). Same applies to the corresponding 'external activation' methods.
  • For video file playback using TVG, SCS now checks if the FFDSHOW Video Codec or the LAV Video Codec is installed. For formats other than wmv it seems that these Video Codecs are more reliable than those supplied with Windows, so if neither of these Video Codecs is available then SCS now displays a warning message (which can be permanently dismissed by selecting 'do not tell me this again').
  • UHD / 4K monitors now better supported for SCS window displays.
  • In MSC Control Send Cues added support for 'Open/Close Cue List' and 'Open/Close Cue Path'.
Bugs Fixed
  • An earlier change that interpreted 'Return' as 'Tab' within the Editor caused problems when setting up or maintaining a Memo Cue. SCS now treats 'Return' correctly when focus is on the memo control.
  • Removing a Lighting Device from Production Properties would throw an error.
  • Panning of a mono file to a stereo output where the output device has more than two channels was not possible if the BASS Mixer was not selected. That is now fixed provided you are using Windows Vista or later.
  • Resuming a fade-out hibernated cue with a fade-in would ignore the fade-in.
  • When adding Image Cues the second and subsequent images may not have successfully displayed when the cues were played from the main window in that same session. (They were displayed OK after restarting SCS or reloading the cue file.)
  • Fixed a problem that prevented 'gapless' playlists from playing gapless.
  • When only one device map exists, the 'Delete Device Map' button in Production Properties should have been disabled. Clicking the button when only one device map existed would throw an error.
  • When sending MTC (MIDI Time Code), a thread lock could timeout causing a delay in the MTC sequence.
  • Fixed an error in editing Playlist Cues - the transition fields should have been disabled when the currently-selected playlist item is blank. Trying to set a transition field on such an item would cause a memory error.
  • Video/Image fade outs initiated by MIDI cue control messages were ignored.
  • When using SoundMan-Server (SM-S), fade in levels could briefly exceed the target level due to the gain level being sent to SM-S.
  • Error messages displayed when editing a Video/Image Cue could be repeatedly displayed if the message dialog was positioned over the video/image preview control.
Some features may not be available in all license levels. Please check the 'Feature Comparison' section of the Help for details.
Re: SCS 11.5.2.1 Available
Posted: Tue Sep 20, 2016 10:33 am
SCS 11.5.2.1 is now available, which contains the following changes:
New and Changed Features in SCS 11.5.2.1
  • A 'Go To Cue' will no longer close a later Memo cue if that Memo cue has an activation method of 'external' or 'hotkey'.
Bugs Fixed
  • Fixed a bug in 11.5.2 that assumed all lighting cues were of zero length and so prevented the progress slider etc from showing fade progress, even though the separate DMX Send thread processed fades correctly.
Re: SCS 11.5.2.2 Available
Posted: Mon Sep 26, 2016 2:52 pm
SCS 11.5.2.2 is now available, which contains the following changes:
Bugs Fixed in SCS 11.5.2.2
  • Fixed a condition that could cause a cue's state to be set to 'not loaded' even though the sub-cue(s) were set to 'ready'. That caused SCS to prevent the cue from being played. This situation occurred after applying a change in the editor (eg a change to the loop start time) and then starting and stopping playback in the editor.
  • Sometimes SCS would play a short part of an audio file after the designated 'end at' position. This only occurred when using DirectSound with the BASS Mixer option selected.
  • A cue set to auto-start n.nn seconds after the start of another cue, where the new cue contains multiple sub-cues with relative start times, could cause the new cue to be continually re-started.
  • A 'note' hotkey with multiple sub-cues would only activate the first sub-cue on second and subsequent presses of the hotkey.
