The small community theater I work with is looking to replace its 24 channel analog Soundcraft board with a digital unit that integrates with SCS. I know Mike has done a super job of building in X32 integration into SCS. Even though we have used numerous Behringer components over the years they seem to struggle with quality control. That makes me a little nervous. So, I have been investigating the Midas M32. Now I know Behringer and Midas are owned by the same parent company, but reading reviews of the Midas unit, there are no mentions of wonky quality. I also like the physical design of the M32 better than the X32.
Sooo, the real question is..... since the m32's core is based on the x32 software can I assume that to use SCS with a M32, you simple set it up as if it were an X32 and use all of the same X32 commands?
Any comments would certainly be welcome as we need to replace this current board in the next couple weeks.
X32 vs M32
Re: X32 vs M32
I can't confirm that the M32 is currently supported by SCS but I do not anticipate any issues. The reason for this is that the programming in SCS for X32 support was significantly based on information in the document Unofficial X32/M32 OSC Remote Protocol by Patrick-Gilles Maillot. Near the start of this document is this statement: "This document should also apply to M32, a product from Midas, very similar to X32."
If you do purchase an M32 and have any issues interfacing SCS with the M32, let me know and I'll see what can be done to provide M32 support.
