SCS 9 notes for SCS 8 users
Post by Mike Daniell » Sat Apr 29, 2006 9:04 am
This is an extract from an earlier posting about SCS 9 (the posting has since been archived):
For current SCS 8 users I suggest you download scs9notes.zip. This contains a Microsoft Word document that explains the main differences between SCS 8 and SCS 9.
SCS 9 can be installed on the same pc as SCS 8, so you can still use SCS 8.
Post by Mike Daniell » Mon May 08, 2006 7:50 pm
This document is now also available as a PDF file. You can download this from www.soundcuesystem.com/download/scs9notes.pdf. To save a copy of the file, right-click on the link and select "Save Target As...".
Note. You need Acrobat Reader installed to view and print the file. Just follow the link below if you need to install it.
Thanks to Matt Downing for converting the MS Word document to PDF.
