Edirol FA66 device not available in ASIO options?
Artales
Post by Artales » Fri Aug 31, 2012 5:24 pm
Hi Folks,
I can't get my FA66 firewire to appear in the ASIO options. It should be the BASS option shouldn't it? Do I need to install anything BASS related?
Could it be because I'm running Win 7 x64 with a FA66 64bit driver? I've tried a few other apps without an issue.
I'd be grateful for some advice, I have techs looming. :twisted:
Cheers
Re: Edirol FA66 device not available in ASIO options?
Post by Mike Daniell » Fri Aug 31, 2012 6:03 pm
Which version of SCS are you using? If you are using SCS 11 then do you have your Audio Driver set to ASIO (using BASS)? See Audio Output Devices in the SCS Help for more info.
I wouldn't think it's due to using a 64bit driver - I have an M-Audio Fast Track Ultra 64bit driver installed on my machine and SCS successfully accesses this device.
Artales
Post by Artales » Sat Sep 01, 2012 3:22 pm
Fantastic. Thanks Mike. Doh, I didn't see that menu, I haven't had the time to read the manual. Excellent application.
