Transport Controls & Cue Go Interaction (in SCS 11)
Posted: Fri Apr 20, 2012 2:14 am
If you start the cue at the top of the cue panel using its transport control, the "Next Manual Cue" is not advanced, thus the Cue GO (spacebar or right click) will not start the next cue unless it's activated twice or until the currently running cue completes or is stopped with its transport control.
This can be illustrated with the demo file. If you use the spacebar to start QI (Fanfare), the "Next Manual Cue" advances to Q2 (Helicopter) and can be started while Q1 is running with the next spacebar press. If you start Q1 using the transport control, the "Next Manual Cue" remains at Q1 and you need to press spacebar twice to get Q2 running.
Admittedly, the transport controls should not be used to run a show, but for consistency perhaps clicking the "Run" transport button should have the same effect as starting the cue with the GO command.
