Linking Multiple SCS installs - MIDI or RS-232
Posted: Tue Dec 27, 2011 1:45 am
I'm working on an upcoming show where I plan to use 2 installations of SCS to run video and sound effects as well as remotely control an ETC Express. In doing some testing with all 3 devices next to each other, I've discovered that the Express doesn't always pass on MSC commands destined for devices on its Thru port if the previous command was destined for it. I will be calling ETC next week on this, but for a 25ish foot control run, would I be better off investigating the use of RS-232 to remotely trigger one of the SCS installs? Also, will SCS respond to RS-232 or MIDI cues if it does not have focus?
The current planned setup: SCS-Video -> ETC Express -> SCS-Audio. The Video playback machine is in the lighting booth next to the Express, and Audio is 1 floor down where its also used as an interface to the mixing desk. I can't combine the SCS systems for a couple different reasons including the SCS-Video machine not having a sound card of good enough quality, the SCS-Audio machine not having enough horsepower to play video (or a second output), and the theater's desire to, when I'm not involved with a production, retain the ability to run lighting, audio cues, and video cues independently of each other with no MIDI or RS-232 links.
Thank you very much for any advice/tips. I've done this before, and ended up using the video play back's onboard sound which just did not have enough of an output level to be useful.
