Copied Time Based cue ignored
Posted: Tue Jul 05, 2011 5:12 am
by Criterion_Earlsdon
Our pre-show announcements are a time-based cue with a number of sub-cues (5 minute; 3-minute; 1-minute; switch off your telephones!) played over a number of outputs. Therefore, I tried copying this from a previous show. In the editor window, it looks fine, but the run window ignored it. I deleted the copied cue and re-entered it from scratch. It now works fine. Does anyone know any reason for this?
Dave Cornish
Criterion Theatre
Coventry
Re: Copied Time Based cue ignored
Posted: Tue Jul 05, 2011 5:45 pm
Should work OK provided you have Time Profiles defined in your Production properties with exactly the same names as those in the cue file you are importing cues from. I presume you are using 'import cues from another SCS cue file'?
Posted: Wed Jul 06, 2011 1:14 am
by Boswell
It works OK in 10.7 and previous versions, I use it every time I set up a show and just copy the basic setup into a new file.
Now that is something I can try in 10.8
Posted: Thu Jul 28, 2011 9:46 am
Thanks Mike, good thought, though I'm not sure if it was the problem. Something for me to re-check on the next show where I will have upgraded to 10.8.2
Dave
