I keep getting an error message "Unavailable Speaker". This happens sometimes when I'm adding a new cue and sometimes when changing a cue. I will not be changing speakers just cue material.
Any clues?
unavailable speaker
Re: unavailable speaker
You will get that message if you try to set up a cue with a stereo file to be played to a mono output, unless the file is MP3 or unless you are using the SCS internal mixer. I suggest you convert the file to mono using GoldWave or similar software.
Thanks Mike!! Will add Goldstar right away.
I of course mean GoldWAVE
