Inserting a Cue in Existing Prpgram
Posted: Mon Feb 28, 2011 11:26 am
by smbrown
As a prospective purchaser of The SCS Pro version, a quick question, which may appear stupid, but I shall ask anyway:
Once a program is set-up and I wish to INSERT a NEW QUE into that existing program, is THAT POSSIBLE? And, how easy is it?
Thank you.
Steve Brown
BrownUllstrup Performing Arts Foundation
Salem, Wisconsin
Re: Inserting a Cue in Existing Prpgram
Posted: Mon Feb 28, 2011 11:59 am
Yes, Steve, it's easy to insert new cues. In the Editor you will see a cue list on the left. Click on the cue prior to where you want to insert a cue, and then click on the appropriate 'Add ... Cue' button, such as 'Add Audio File Cue'.
Using the arrow buttons to the left of the cue list, you can also move cues up and down the list, convert cues to sub-cues, or convert sub-cues to cues.
Posted: Mon Feb 28, 2011 12:20 pm
by smbrown
Thanks Mike!
Posted: Tue Mar 01, 2011 7:08 am
by Willarki
Which raises a possible change request.
In every other application I use that has tables or similar (eg Word, Excel), insert does so before the current row. Which is why I no doubt when inserting a cue in SCS, it invariably initially ends up in the wrong place.
Posted: Tue Mar 01, 2011 3:38 pm
Willarki wrote:Which raises a possible change request.
I see your point, Mike, but the reason is that when you start a new production there are no cues, just a single 'node' in the list which is the Production Properties node. So clicking 'Add...Cue' adds a cue
after that node. From memory I recall that Excel asks you if you want to insert a row
before or
after the currently selected row, which is an extra step in the process.
Posted: Tue Mar 01, 2011 10:49 pm
by Boswell
Mike Daniell wrote:From memory I recall that Excel asks you if you want to insert a row before or after the currently selected row, which is an extra step in the process.
Correct Mike, top of the class, leave SCS as it is, you soon get used to it
