Number of loops cannot = 1?
escrge
Post by escrge » Thu Sep 17, 2009 3:27 am
Using 10.6.1:
SCS won’t let me use a single loop. It says I have to use a number >1. So I can have unlimited or 2, but not one? Two loops is too long for my current need.
David H.M. Lambert
Lambert Studios
http://www.LambertStudios.net
jmgordon
Re: Number of loops cannot = 1?
Post by jmgordon » Thu Sep 17, 2009 5:03 am
Have you tried it? The pop-up label on the loop count box says "Number of times the looped part of the sound is to be heard...". Surely, if it's only heard once it's not a loop. If you enter "2", it will loop back once only and then play to the end.
escrge
Post by escrge » Sat Sep 19, 2009 12:40 am
Hmm... I suppose the value of >1 seemed a bit misleading. I expected to enter a value of 1 to loop once. Instead I need a value of 2 to play a certain section twice. I suppose it's just a matter of semantics. Never mind.
David H.M. Lambert
Lambert Studios
jkowtko
Post by jkowtko » Sat Sep 19, 2009 3:15 am
Mike, if there's a lot of confusion on this, you might consider using a term which is clear on whether or not the first iteration is included in the count ... for example:
- "# iterations" includes the first time through the audio section
- "# repeats" does not include the first time through.
Maybe those aren't very clear either ... :|
John Kowtko
Sound Designer/Engineer
Redwood City, CA USA
Post by Mike Daniell » Sun Sep 20, 2009 4:33 am
jkowtko wrote:Mike, if there's a lot of confusion on this, you might consider using a term which is clear on whether or not the first iteration is included in the count ...
Yes, this is probably the best solution. I remember not being sure whether to make the 'number of loops' inclusive or exclusive of the first iteration, and for some reason settled on making it inclusive.
