I have noticed a couple of requests for an SCS Manual. For those of you who have Adobe Acrobat you can create a printable version of the Help file in about 15 minutes. Here is how it is done:
1) Open the help file and go to the Contents menu where you should see the 8 headings: Contents-Disclaimer.
2) Select a Heading and then select Print.
The Print dialog box should appear. Select Print the selected headings and all subtopics and click OK.
When the Print Box appears select the Adobe PDF printer and set whatever print quality preferences you like.
Print the file to a folder.
3) Continue to do this for all 8 headings.
You are going to have some rough looking page breaks but it makes a reasonable and usable printable version (for personal use) of the help file.
