Run Time error (fix in 9.5.4)
Posted: Tue Jan 13, 2009 4:42 am
by Nigel Bayliss
I'm running SCS 9.5.3 and when I am in the editor, purely clicking on the left hand cue list (to view the cue's parameters), I am getting the following error:
'Run time Error'
2147220988 (80040204)
Attempt to add rows with no columns
It happens when I click on a midi send cue with a timebased start...and I think(?!) it also happened when clicking on a timebased playlist. It then shuts scs down completely, and on re loading it, if I do the same thing the fault doesn't occur.
My theatre machine is running Windows XP home, and my laptop is running Windows Vista Home premium...both have the same problem.
Re: Run Time error
Posted: Tue Jan 13, 2009 11:09 am
What I expect is happening is you are using a Time Profile that doesn't exist in your Production Properties. SCS should, of course, prevent that happening. Could you email me your cue file (the .scs file)?
Re: Run Time error
Posted: Thu Jan 15, 2009 4:10 pm
Problem found - I'll issue a fix shortly. The error occurs if you:
  • Open the Editor and click on a Time Based Cue (or set a cue to Time Based), then
  • Close the Editor, then
  • Re-open the Editor and click on a Time Based Cue (or set a cue to Time Based).
This error is in SCS 9 only - it is not in SCS 10.
