(SCS11.7.0) Video playback woes
adamhawes
Post by adamhawes » Sun Apr 22, 2018 11:00 am
SCS 11.7.0-x64 on Windows 8.1. The Windows install is pretty-much vanilla with all current updates installed. I installed SCS with LAV filters and they appear to be installed correctly. Video driver and renderer are left at the default settings (TVG/auto). Video file is MP4 - H.264 (640x480) with AAC audio, but LAV filters seem to support that combination.
I have a show with a 4x4 USB audio device connected. I have a device map for ASIO (BASS) that works great for all my audio-only cues. Video cues do not map to the USB device though. Their sound is rendered to the headphone socket on my laptop. In a pinch I could feed this to the mixer too but that's a bit of a hack that I'd rather avoid - the headphone output on my laptop is quite noisy. There are no options on the video cue to route to the external device. My device options are "Default" and "Mute". I guess I could extract the audio separately, run it in parallel and mute the video. That will probably create some lip-sync issues though.
The video also renders full screen even though I have asked to scale it to 50%.
Tech starts during the week, show opens in a week. Any hints would be hugely appreciated.
Re: (SCS11.7.0) Video playback woes
Post by Mike Daniell » Sun Apr 22, 2018 12:30 pm
I've emailed you details of a new version that I hope will fix the video size issue. Unfortunately, all the video playback libraries I've tried (including TVG) only support DirectSound, not ASIO.
adamhawes
Post by adamhawes » Sun Apr 22, 2018 12:52 pm
Thanks for the reply. I'll test out the links you emailed me and report back. I have DirectSound drivers for my interface but they only showed 2 channels on my desk system (Windows 7). It might be OK on my laptop. This is OK for the current show so I'll give it a go and see how it works.
A
Post by Mike Daniell » Sun Apr 22, 2018 1:08 pm
Yes, some audio interfaces that primarily support ASIO just support 2 channels of DirectSound.
adamhawes
Post by adamhawes » Sun Apr 22, 2018 2:02 pm
The test binaries fix my scaling issue and also the audio issue using ASIO. I was all set to select DirectSound but when I tested the video to see if it has scaled I got audio out my USB interface without making any changes.
Looks like I'm a happy camper.
Thanks for the quick turnaround.
jmusco
Post by jmusco » Thu Apr 26, 2018 3:31 am
adamhawes wrote:Hi Mike,
I'm having the same scaling issues. Can you send me the fix you sent the OP?
