10.7.4 problems with playlist sub-cue
d_korman
Post by d_korman » Sun Nov 14, 2010 10:09 pm
I'm working on some complex cues for a radio play and am getting some random misbehaviours around sub-cues not resetting when I back up and similar issues. Very hard to document as they are not repeatable.
However, I have two problems that are repeatable:
1) after I play a cue that has an audio file and a playlist file subcue, when I stop the cue and then play it again I get a very short burst of the 1st playlist file (about 0.2 seconds, if that) at its full volume (it has a fade in set), then it drops to the correct level and fade in.
2) If I add relative start time to the playlist cue, the fade in time is ignored.
Dave
tdecker
Re: 10.7.4 problems with playlist sub-cue
Post by tdecker » Mon Nov 15, 2010 12:24 am
Our's does that burst of audio with the playlist que, as well. But, since we haven't needed to restart a playlist que from a cold (so, not using hibernate) except during tech, it hasn't been an issue for us.
Tristan Decker
Technical Director and Resident Set and Lighting Designer
Margaret Jonsson Theater
University of Dallas
www.udallas.edu/drama
Post by Mike Daniell » Mon Nov 15, 2010 8:57 am
d_korman wrote:1) after I play a cue that has an audio file and a playlist file subcue, when I stop the cue and then play it again I get a very short burst of the 1st playlist file (about 0.2 seconds, if that) at its full volume (it has a fade in set), then it drops to the correct level and fade in.
Can you email me a cue file (.scs file) that does this? I've tried to reproduce the error but I'm not getting the short burst - the fade in works correctly every time.
d_korman wrote:2) If I add relative start time to the playlist cue, the fade in time is ignored.
Confirmed. I'll work on a fix.
d_korman
Post by d_korman » Wed Nov 17, 2010 8:26 pm
Have e-mailed you the cue file just now.
