Video on 2nd Monitor
I am on 10.7.4 & I can get videos to play ih the test panel but not on the 2nd monitor. I am on XP SP3.
Any suggestions?
Thanks, Chuck
Any suggestions?
Thanks, Chuck
Re: Video on 2nd Monitor
See the new section in the Help file for SCS 10.7.4 entitled Setting Up Your Video Projector For Videos and Still Images (under Production Live Running). This is also applicable for setting up a second monitor.
Desk top show on project when SCS is not open , when it is it goes to black as pervious version, but when I put video cue onto play on external monitor nothing come sup, just the screen remaining black
I can play in in edit mode on the preview but clicking back on Monitors and it's blank
Try changing the Video Playback option (under General Options / Permanent Options).
If that doesn't help, try a different video file format. Some MPEG formats, in particular, are known to be incompatible with installed codecs and it may be necessary to install different codecs. See the Forum topic Tips on Video cues for more info.
Mike, Changing it to WMP did fix it. I was looking for this option but waqs looking for it in its own tab. What DirectShow component needs to be installed? I have WMP classic which uses directshow & the videos play fine in that.
If you have DirectX 9 or later you should be able to play videos using the DirectShow option in SCS. However, video file 'standards' are notoriously non-standard, which is why there are numerous codecs to choose from. WMP does seem to handle more formats than native DirectShow, probably because the designers had more inside knowledge of the DirectShow API's.ChuckTX wrote:What DirectShow component needs to be installed?
Now after changing to WMP the images will not fade out. They fade in but not out. Any suggestions?
Can you email me your cue file (the .scs file) and tell me what image cues don't fade out? I've just tried it here and images fade in and out as required even when using WMP as the Video Playback option.
Re: Assininga key for fading sound
If I can assinge a key to cue in the next cue but I can aasinge a fade button for scen change music which can't be timed
alsostopping a sound cue
I have soem back ground sound for soem scenes which I cant autonalicaly cue out when the video switces so when I fade out the scene change music fades out into teh next scene teh back ground sound is still running if I havne't mannualy faded it out befor eth cahneg has finshed
Sorry - can't understand the posting.Methodman wrote:If I can assinge a key to cue in the next cue but I can aasinge a fade button for scen change music which can't be timed
Now on wmp for the playing option not all of my videos are starting with the right cue. All of the ones that I am using in this show are tied to a sound cue & are set to start 0 sec AS of Cue. Some are very short, like 2 sec. They will start but not right away even though the play bar is moving on their cue. Any suggestions on how to get my 2nd display going with directshow, since that's the way you think it should be run anyways? I have DirectX 9.0c installed. Intel series 4 integrated graphics on a Dell. Is there a way to pre load video files? I don't know if that's why it isn't playing them quickly.
Thanks, Chuck
Thanks, Chuck
