supported audio devices
sparky7854
Post by sparky7854 » Wed Oct 01, 2008 3:40 am
Hi
I am wondering if this software supports the M-Audio products I am looking at using M-Audio Fast Track Ultra 8R, However if some one can suggest something else that has 8 outputs that would be great.
Cheers
Re: supported audio devices
Post by Boswell » Wed Oct 01, 2008 4:11 am
Maudio Delta 1010 & Delta 1010LT (Both internal)
Gigaport HD (USB)
All work OK with SCS10
There are others but I have not used them, other members should be along shortly :D
jkowtko
Post by jkowtko » Wed Oct 01, 2008 5:48 am
Revolution 5.1
Revolution 7.1
Delta 44
Delta 66
All work fine, although the Deltas sound MUCH better than the Revs due to balanced outputs and professional output level (+4dBu vs. -10dBu for the Revs)
I also own a FastTrack Pro, but haven't used it for SCS output as yet.
John Kowtko
Sound Designer/Engineer
Redwood City, CA USA
sparky7854
Post by sparky7854 » Thu Oct 02, 2008 3:05 am
Thanks Guys
I think I am going to give the fastrack 8r a try, It works for what I need.
Cheers
jkowtko
Post by jkowtko » Thu Oct 02, 2008 4:18 am
Seems like a nice unit.
I'm curious to know if a USB device can support the bandwdith of 8 simultaneous outs (or ins for that matter) without glitching ... please send us an update when you've worked with it. If it works well, I may want to get one!
Thanks. John
John Kowtko
sparky7854
Post by sparky7854 » Thu Oct 02, 2008 1:13 pm
It should work no problem as I have no intentions of using the inputs at this point, just the outputs.
dikt
Post by dikt » Tue Oct 07, 2008 10:35 pm
I previously used an m-audio firewire 4/10 with 8 audio channels out. Since version 10 of scs I am using an m-audio 18/14 and have 8 channels of audio from the ADAT optical out straight into my Yamaha 01V96 mixer. No wires !! Brilliant !! This also means that the channels 1-16 of the mixer are freed up for band etc. No problems at all so far.
Dik Thacker
jkowtko
Post by jkowtko » Tue Oct 07, 2008 11:03 pm
ADAT to the 01v? That's great ...! I posted a thread on this a while ago and at the time nobody seemed to have tried it. Glad to hear you can utilize all eight channels.
John Kowtko
Post by djvomght » Wed Oct 08, 2008 5:06 am
tested SCS 10 with following cards:
- Soundblaster PCI (one onboard, one in PCI slot)
- Echo Layla 20
- Marc Marian ADAT card into M7CL
All work fine.
Regards Jörg
SuperDave1276
Post by SuperDave1276 » Wed Nov 26, 2008 4:03 pm
Greetings,
Just thought that I'd throw my 2 cents out there. I have been using an M-Audio Transit USB and an Alesis Multimix 8 USB for about two years now, and have added an M-Audio Quattro USB about 9 months ago. All work beautifully.
Cheers,
David S Erickson
Technical Director
Northwest Classical Theatre Company
Portland, Oregon
USA
Post by Boswell » Tue Jun 29, 2010 3:24 am
Also tried a Maudio Fast track Pro (USB) from a laptop and a Roland (Cakewalk) UA101 USB from a desktop
Both work fine no problems.
Post by Mike Daniell » Tue Jun 29, 2010 12:29 pm
Change the 'type' of this topic to 'sticky' so it stays at or near the top of this Forum. Feel free to add more supported devices.
sound
Post by sound » Wed Jun 30, 2010 7:17 am
RME Fireface UC
RME Digiface
Greetings,
Walter
Theatre III Sound
Post by Theatre III Sound » Wed Jun 30, 2010 10:20 am
Presonus Firebox - 6 balanced outs - May have been discontinued.
Behringer UCA222 - Inexpensive 2 unbalanced outs - I carry one in my computer bag to use in a pinch for FOH music and such.
derick
Post by derick » Thu Jul 01, 2010 3:13 pm
Steinberg VSL2020 16 ADAT in and out to Yamaha 02R
Sound & theater technician
Schouwburg Kortrijk
Belgium
