Another minor problem for you!,
XPpro, SP3, all updates applied, 2gb ram, 40g free on HDD, AMD133cpu
Delta1010L soundcard
Using 10.6.2tr (But it also appears in 10.6.1)
I have set ‘Windows/properties/Appearance/advanced/selected items’ to bright green. This means that in SCS the next active cue appears in bright green.
Zipped up trace, SCS & SCC files sent by PM. Using SDC colour scheme.
When I get to Q188 ‘Interval wallpaper’ which is a looped audio wav file, the next active cue in the list Q190 ‘Fade out Wallper’ is not highlighted in any way. This continues down the list with all cues working but not highlighted until I get to & run Q196 when all returns to normal!! All the cues between 190 & 196 are control/send midi cues.
I’m sure this did not occur in earlier versions (or it is obscure and we have not seen it). I’ve tried 2 computers with the same effect and it is repeatable.
Highlighting of Next cue
