9.2.5 crashing while adding cues.
drobkin
Post by drobkin » Sat Sep 16, 2006 7:13 am
I have the same Dell laptop running Windows XP home. If I try to add more than 2 or 3 cues or subcues between saves i get a "subscript out of range" error and the program closes. This has happened three time this morning.
These are regular numbered cues, not playlists.
Dave
Post by Mike Daniell » Sat Sep 16, 2006 7:16 am
Can you supply all the details included in the message, or preferably email me a screenshot of the error?
mdaniell@optusnet.com.au
Jon Wiles
Post by Jon Wiles » Sun Sep 17, 2006 8:45 am
Had the same problem with adding a fade cue after a cue with a fade time (9.2.5). Had to save after each cue added. Using IBM laptop at the time. Just tried at home (desktop) using 9.2.6 and all is OK. Will try with IBM next week.
Jon Wiles
Jon Wiles
Post by Jon Wiles » Tue Sep 19, 2006 12:19 am
Dell laptop at work has the same problem with 9.2.5. Just tested with 9.2.6 and all is well. Suggest 9.2.6 is the answer!
Jon Wiles
