Linking the audio progress slider and MTC
icthelight
Post by icthelight » Fri Mar 08, 2024 9:31 pm
Under MTC (MIDI Time Code) Cues and LTC (Linear Time Code) Cues, the documentation says, "Also, if you drag the progress slider on the Audio File sub-cue, then the MTC will be adjusted accordingly."
Does this work? Are there any tricks to making it work?
Re: Linking the audio progress slider and MTC
Post by Mike Daniell » Sat Mar 09, 2024 6:03 pm
See the example below.
the MTC sub-cue is shown as linked to the audio file sub-cue, and whilst playing the cue I clicked on the progress slider. MTC immediately adjusted to match the new position.
icthelight
Post by icthelight » Sun Mar 10, 2024 10:44 pm
Thanks for your reply, Mike. I worked out that the problem in my show was that I set a Rel. Start Time of 4 seconds on the audio track to match the 4 seconds of pre-roll on the MTC track. When I removed the Rel. Start Time, the two tracks did become linked.
I suppose I could use a DAW to add 4 seconds of silent audio to the beginning of the audio track. Is there any other way I could synchronize the two tracks while retaining a short delay at the start? I need to give my lighting console a chance to sync up with the MTC signal before the song begins.
icthelight
Post by icthelight » Tue Mar 19, 2024 2:13 pm
Is it a bug that the setting of a Rel. Start Time de-synchronizes the audio track and the MTC track?
Post by Mike Daniell » Wed Mar 20, 2024 8:52 am
Not really a bug but a scenario I hadn't considered. I'll look into supporting this shortly.
