Hi there, I have a problem I hope someone can help me with.
I've created a level-changing subcue, to change levels on two different channels. I think I've set everything up properly, and the test works as expected, but when I fire the cue, the sub-cue 1 fires normally, but the level-changing cue immediately shows as being "Completed" and no change in levels occurs.
Marc.
Subcue Doesn't Fire in 9.2.2
Erm, it works now....
Actually, I just got back from rehearsal and it seems to work now. I did find I had problems when I put in a relative start time for a sub cue. I found that sometimes it also filled in that same time on the first sub cue, which also messed things up. I suspect it happened because I was filling in a relative time to start the sub cue before picking the cue to modify, but I can't swear to that because I don't think I can replicate the bug (and don't want to until the show's run is done
SCS was behaving very badly for a while today, but I suspect that a lot of my problems were arising from a different program that seems to have a memory leak.
Thanks for checking in on the post, and I wish I could be more certain about the source of the problem.
Marc
Marc
