for example, we do allot of award shows where there is an award sting (audio cue) followed by a fade cue (SFR) maybe 30 to 50 per show and I like all of my award stings to be called A01 to A50 and then the Fade cues to be called F A01 to F A50. This would be easy if I could select ever other cue to be renamed, or select only audio cues within a region to be renamed A01 to A50 and later go back and select all SFR cues in the same region to be renamed F-A01 to F-A50. I hope this makes sense, some of our shows are so long and its nice to look and see where you are, and it can be a pain when I add in an extra sting at A11 then have to individually rename every cue after this one
It is still important to do this in sections/ regions rather than rename all audio cues as I use allot of audio hotkeys which I don't want to rename as these are normally called the letter of the keyboard they are assigned to.
Thank you in advance. Jay.
