[Resolved] VST-Plugins
VST-Plugins: I miss the mounting tab for VST-Plugins in SCS11.8.2 but the plugins are stille aviable in a cue, if there are mounted trough an older version of SCS ?
Re: VST-Plugins
VST Plugins are now set up from a new 'VST Plugins' button in the Main Window Toolbar. An enhancement in SCS 11.8.2 enabled VST Plugins to be applied to Audio Output Devices, and to test the plugin settings for an audio output device it is best to run a cue from the main window and make adjustments while hearing the cue playing.
