[Resolved] Audio Output Channels, only see 2 channels
bsanker
Post by bsanker » Tue Mar 26, 2019 4:39 am
Not sure if this is a SCS, SM-S or windows problem. I have SM-S with 16x16 channels but can only select the 2 channels going out. I am connected to a Mackie DL32r via USB. I can see all 32 channels in the windows mixer but can only select 2 channels (L/R). Since I am using SM-S I select channels 15 and 16. SM-S is supposed to allow all 16 channels of output. How do I get windows to let me output all?
As a work around I am sending my live microphones out through the 2 channels with my SFX but would like to be able to also send to other components like the monitors or intercom system without being heard in the house sound.
jmgordon
Re: Audio Output Channels, only see 2 channels
Post by jmgordon » Tue Mar 26, 2019 7:19 am
I know very little about SM-S, but are you using the dongle?
I read in the Help file:
Important Note: If you have an SM-S license and dongle, then please use the dongle! Running SM-S without the dongle restricts you to demo mode which at the time of writing supports only 2 inputs, 2 outputs and 4 playbacks.
Just a thought. May be something else entirely.
Post by Mike Daniell » Tue Mar 26, 2019 8:44 am
What do you have selected as the Audio Driver in SCS? See Production Properties - Audio Output Devices. You should have "ASIO (using SM-S)" but from your explanation it seems like you have "DirectSound".
bsanker
Post by bsanker » Wed Mar 27, 2019 9:29 am
Mike had Asio (SM-S) selected. I solved just solved the problem. I was mapping the channels backwards in the Mackie Masterfader app.
