I had a short embarrassment on Saturday when running SCS.
I'd successfully run one set of cues into a Yamaha MG20XU mixer. On loading the second set, I found that I'd not configured it to use the MG20, so the sound was sent to a projector I also had attached. I know the process, which was to unlock the editor, then go into the production properties, devices, and change it. About 6 mouse clicks to get to it. Trouble was, first time, I was 'unable to save' as the actual save button is off the screen as you have to scroll down to get to the buttons unless SCS is in full screen mode. I was hitting the main Editor Save button lop left that was of course fully visible but wouldn't work!
There's a lot of yellow above the action buttons. Could you consider providing a quicker way to change the current output device, or move the action buttons up the screen so they are more visible please?
Thanks ..... Robin
