SCS 11.8.0.1 Available
Locked
Post by Mike Daniell » Mon Jan 21, 2019 1:47 pm
Registered users with current update plans (including users who purchased or upgraded their SCS license during the last 12 months) may now download SCS 11.8.0.1 from the Download page of the Member Area. This is primarily a bug-fix version so the release date (for download purposes) has been back-dated to that of SCS 11.8.0.
Changed Features in SCS 11.8.0.1
  • In Lighting Cues the Chase Speed (BPM) field in the Editor can now be set using the 'Tap Delay' keyboard shortcut (eg Ctrl+.) even if the cue itself does not have 'Monitor Tap Delay' selected.
  • In Lighting Cues the Live DMX Test checkbox is now 'sticky', ie once set it remains set until you clear it or you close the editor.
Bugs Fixed in SCS 11.8.0.1
  • VST plugins were not processed correctly for audio file cues with a cross-faded loop. (SCS opens the file twice if a cross-faded loop is specified.)
  • Some ASIO drivers appear to stall during even a short period of inactivity. Previously this would cause playback in SCS to stall. When SCS detects that the ASIO driver has stalled, it now resets and restarts ASIO, and that re-awakens the driver.
  • Deleting a Fixture Type (in Production Properties) would not remove that Fixture Type from the list, and deleting the last remaining Fixture Type would throw an error.
  • In a Lighting Cue with Chase set, if the number of chase steps was increased then the new chase steps were not initialized, so it was a bit random what would have been loaded into those steps. SCS now initializes the additional steps with the settings of the step that was previously the last step, eg if increasing the number of steps from 4 to 12 then the new steps 5-12 will be initialized at the settings of step 4.
  • For SCS Lite users, a memory error would occur on trying to access Options.
Some SCS features may not be available in all license levels. Please check the 'Feature Comparison' section of the Help for details.
Re: SCS 11.8.0.1 Available
Post by Mike Daniell » Fri Feb 01, 2019 9:35 am
Regarding VST Plugins, note that plugins from waves.com are not directly supported even when selecting the respective WaveShell-VST DLL. However, you may be able to split the plugins into separate VST DLL's using a product call shell2vst. Contact support@showcuesystems.com if you need more info.
Locked
