Hello Mike and all,
during rehearsals of of our lates production I run into some problems with cue markers.
1. Setting a quick cue marker by clicking right in the editor sets acue marker, which is not recognized until You have played some seconds around the marker at least once.
2. If You insert a cue before an audio cue containing cue markers the first cue marker will fail and the cue to be triggered ist started with the next cue marker.
These issues are gone after saving and restarting SCS.
I did the tests with 11.8.0b3 x86, but it hides also in the latest regular version.
I attached log file (needed to repack it with Rar because it was to big) and diagnostics file.
Best regards
Jörg
[Fix 11.8.0] Cue Marker Issues
- scs11diag_20181126_140128.scsz
- (55.35 KiB) Downloaded 65 times
- scs11_log_20181126_134854.rar
- (168.97 KiB) Downloaded 52 times
Re: Cue Marker Issues
Could you give me more info on how to reproduce this? It works OK here. For example, trying to follow your sequence of events approximately, I created a new cue file and add several audio file cues. I then selected one of those cues and did a right-click on the graph to set a cue marker. The cue marker was visible in the graph and in the progress slider. I then set another cue to auto-start on that cue marker. After closing the editor I played the first of these cues. The second cue started as expected when the cue marker was reached in the first of those two cues.djvomght wrote:1. Setting a quick cue marker by clicking right in the editor sets a cue marker, which is not recognized until You have played some seconds around the marker at least once.
This may perhaps only happen when the editor is not closed.
The second problem occurs when You are doing this:
- Open an existing file or create a new one.
- Open the editor and add a cue (seems no matter of what kind it is) before an audio cue containing cue markers.
- Switch back to cue list: When play the audio cue, the first cue marker is ignored.
Confirmed and now fixed both issues. We're hoping to issue the first 'release candidate' of 11.8.0 later this week and these fixes will be included.
