[Resolved] Time based cue vanishes in Rehearsal mode
Criterion_Earlsdon
Post by Criterion_Earlsdon » Tue Jun 19, 2018 9:46 am
I am using 11.7.0 but I think I have seen this problem with earlier builds too.
I have had shows where the director has asked for pre-show music, so I've added a Time-based Playlist cue at the top of the show. When I select rehearsal mode to test it, the cue vanishes off the playback screen. As a workaround, I changed the clock on the PC.
I'm emailing a diagnostic file because there's another odd fault too
Best,
Dave
Re: Time based cue vanishes in Rehearsal mode
Post by Mike Daniell » Tue Jun 19, 2018 6:56 pm
Regarding the time-based cue, what you need to do is set the Time of Day to 'Manual' for Time Profile 'Rehearsal' in your pre-show music cue. You can just enter 'm' in this field and SCS will convert that to 'Manual' on saving the cue file. See Time-Based Cues in the Help for more info. As you had no entry at all for the 'Rehearsal' Time of Day, SCS ignored the cue altogether when you selected the Rehearsal time profile.
