I have just downloaded 11.7.0 and found that if I have a cue containing a disabled sub-cue, when I play that cue in the main window, on completion it remains as the next cue to play and the show does not advance to the following cue.
Best wishes
Stuart
[Fix 11.7.1] Cue with a disabled sub-cue doesn't advance
Re: Cue with a disabled sub-cue doesn't advance
Working on it.
Same fault found here
Fix ready. Anyone who needs it now, let me know.
Sorry Mike, another bug associated with disabling sub cues.
If the first sub cue (audio file) in a cue is disabled and the second subcue (audio file) is enabled then the "Give Visual Warning" select "Count UP whole cue" function does not work.
Swap them around so the first sub cue is enabled and it works
see attached
eg test.scs11 works
test1.scs11 fails
see attached
eg test.scs11 works
test1.scs11 fails
- test.zip
- (2.11 KiB) Downloaded 82 times
