I've noticed that call cues are not blocked when an exclusive cue is running.
The help file says "If an exclusive cue is running then the 'Go' button is disabled if the cue displayed on the 'Go' button is or contains an audio or video/image cue", so technically this is working as documented, but in many cases the called cue will contain audio or video cues and we would want the call cue to be blocked by an exclusive cue.
Would it be possible for the call cue to examine its target cue to see if it contains an audio or video image cue, and therefore be blocked if an exclusive cue is playing?
Tim.
[Fix 11.4.1] Call cue not blocked by Exclusive cue
Re: [Fix 11.4.1] Call cue not blocked by Exclusive cue
Thanks for the fix, I confirmed it's working in the show file where I first noticed the problem
