[Mod in 11.4.0.3] Default image duration
howartp
Post by howartp » Sun Jul 19, 2015 7:11 pm
I use image cues a lot, and 99% of them are 'Continuous'.
The default is for 5 seconds - could you add a default duration option like the other cues, with default duration of x seconds or continuous?
Peter
Re: Default image duration
Post by Mike Daniell » Tue Jul 21, 2015 4:20 pm
I started looking into this and realized that if you set a 'Display Time' for an image then when you add another image then SCS defaults the display time to that last used. However, SCS does not do this for the 'Continuous' property. So I have now modified SCS to remember the 'Continuous' property as well. So if you set an image cue to 'Continuous' then that will be set by default for subsequent image cues you add (until you set a 'Display Time').
Will this meet your requirements? I can let you have a pre-release that includes this change.
howartp
Post by howartp » Wed Jul 22, 2015 1:46 am
Yes, that would work.
Don't worry about the pre-release yet; we're on summer holiday for 6 weeks so I won't need it until after that, by which time you might have released another version.
Peter
Post by Mike Daniell » Tue Jul 28, 2015 5:49 pm
Mike Daniell wrote:I started looking into this and realized that if you set a 'Display Time' for an image then when you add another image then SCS defaults the display time to that last used. However, SCS does not do this for the 'Continuous' property. So I have now modified SCS to remember the 'Continuous' property as well. So if you set an image cue to 'Continuous' then that will be set by default for subsequent image cues you add (until you set a 'Display Time').
Mod implemented in SCS 11.4.0.3.
