Loops in midi file cues
rborsey
Post by rborsey » Wed Aug 27, 2014 3:17 pm
Would be super to be able to define a loop in a midi file cue. To put this in context I use a parallel midi file to drive the lights to accompany an audio file playback. If the audio file has a loop then I need a rather complicated set of sub-cues in which one midi file plays which includes a repeated section for the loop - this is then stopped when the loop is released and another midi file is auto started. It works but boy is it a pain to set up (and in particular change). I realise that there are inherent risks in looping midi files (with stuck notes etc) but this is the same risk with start and end points. I could live with some practical limit on midi events in the loop if it helps.
Cheers
Richard
rborsey
Re: Loops in midi file cues
Post by rborsey » Sat Jun 25, 2016 6:23 am
As for multiple loops in audio files this too would make my kind of usage (using SCS to play backing tracks for my band) a Whole Lot easier. Anybody else doing the same sort of thing?
Cheers from sunny France
Richard
