SCS 11.2.5 Relative Start bug (fix ready)
Post by Mike Daniell » Thu Feb 06, 2014 11:23 am
A few users have reported a bug in SCS 11.2.5 in that a sub-cue's relative start is reset the next time the cue file is opened.
This occurs if the relative start time field is blank or zero. What happens is that if this time field is blank or zero then SCS does not save the relative start mode, so setting the relative start mode to 'after end of prev. sub-cue' or 'after start of prev. sub-cue' does not get saved to the cue file.
A fix is now ready for the next release of SCS. Meanwhile you have two options. As a work-around you can set the relative start time to a small value (eg 0.01 second), but if this is not acceptable then email me and I'll provide you with a corrected version.
