Native Resolution Issue w/ Projector
Pochflyboy
Post by Pochflyboy » Sat Nov 30, 2013 11:41 am
Hello,
I have setup a projection mapping show that is being cued and played back by SCS 11 and I am having an issue. The .MP4 video file is rendered at the projectors NATIVE resolution of 1280x800. When the projector is hooked up I have set the resolution to the native (Windows recommends 1920 x 1080 and says that is the native but it is not. There is no projector driver so I am using the generic driver.) The desktop does cover the entire area when the resolution is set to the projectors native resolution.
When I launch the SCS and playback the show it displays the show at a much smaller size. I tried using the "size" feature but the slider jumps too much to be accurate enough. The only way I can get the show to play correctly is if I set the resolution on the PC to 1920 x 1080 however then the entire show is much more pixelated and not nearly the quality.
My Systesm is:
Windows 7
Intel Q6600
GeForce 210
Thanks a million,
Joe
Thanks a million,
Joe
Re: Native Resolution Issue w/ Projector
Post by Mike Daniell » Sat Nov 30, 2013 8:01 pm
Pochflyboy wrote:I tried using the "size" feature but the slider jumps too much to be accurate enough.
Note that in SCS 11.2.5 you can adjust the size using the mouse wheel or the + and - keys. Also, if you hold down a shift key while using the + and - keys then size adjustments are very small - probably just one pixel.
