When I've finished making an adjustment in the Production Editor, I have to press Save and then Close.
Is there a way to combine those 2 steps together?
In using the program, I find I jump in and out of the editor a lot.
In Ver. 8, in the Option menu you could check "Auto-Save after every change" That was very very useful.
Next Question:
Would it be possible to minimise the Production Editor or switch back and forh between the production editor and the main screen?
Thanks. Adair
Fantastic program!
Using the Production editor V9
When I started development of the Editor I had 'OK' and 'Cancel' buttons, but I found I kept clicking 'OK' (which closed the Editor) when I meant 'Save' (which leaves the Editor open). A new 'Save and Close' button would be the easiest solution.When I've finished making an adjustment in the Production Editor, I have to press Save and then Close.
Needs some thought. Some main screen functions are suspended during editing, so minimising the Production Editor would have to reactivate those functions.Would it be possible to minimise the Production Editor or switch back and forth between the production editor and the main screen?
