Inexpensive Laptop Sound Solution
Reading these forums, I saw someone mention that only two outputs of the Audigy 2 PCMCIA card show up in SCS. Are there any other inexpensive cards surround sound cards that work correctly with this program? Either USB, firewire, or PCMCIA, but something under the ~$300 that the m-audio fireware 410 costs would be great for those of us in less professional settings that can't afford to spend that much money on the sound playback.
As far as a standard 5.1 card is concerned I can tell you that my on-board C-Media AC97 works perfectly with SCS and I can output to any speaker. Some users have reported incompatibilities between SCS and Creative Labs cards.
Even though the C-Media card works OK, I wouldn't use it for a production as my M-Audio Delta 44 provides far superior quality and balanced outputs.
I use an emagic 2/6 USB sound card with my laptop which has never let me down. It has 6 outputs. It also has digital I/O on coaxial connections, which is handy if you are working in stereo and using a digital mixing desk. This sound card doesn't appear to be available new any more, but in the UK they regularly come up on eBay for around £100 ($200-ish, I think!).
It is a little bulky to carry around - bigger than the breakout box on the Delta 44 - but it does also double as a 2 port USB hub, and the Digital I/O can be converted to act as MIDI I/O, which can be useful sometimes.
I've never actually tried to use this card to create surround sound with SCS - I've always worked in good old fashioned stereo, and it works fine for that - perhaps Mike can confirm whether the multiple outputs on this card are supprted?
Jack
...thank you for listening...
I use the Griffin iMic USB audio device as the line-out from my laptop at the theater. It works great. You can even use two of them, and run the line-outs to different amplifiers for, say, onstage vs. offstage effects. I think the iMics run about $40 or less, so they're easy to use and very inexpensive.
