Unwanted renaming of a Cue following a move
runawaymartin
Post by runawaymartin » Fri Aug 21, 2009 4:46 pm
Hi Mike . . . this is not really a future request but I thought I might sneak it in here anyway.
Following the moving of a Cue within the editor it seems that it is automatically renamed to the name of the first sub-cue (as it does when a Cue is first created). . . although this is not a major problem it can be a bit of a nuisance having to alter the 'Description' back each time, particularly when there's a lot of shuffling to be done.
Maybe this is done on purpose for a specific reason?
The recent fix following a move (where the Cue was being expanded) has been gratefully received . . . thanks . .
Cheers . . . . Martin
jkowtko
Re: Unwanted renaming of a Cue following a move
Post by jkowtko » Fri Sep 18, 2009 8:50 am
I think I've noticed this before as well ... in general the coordination of the description fields at the Cue and SubCue level is a bit confusing.
In conjunction with the above request, Mike, would you also consider greying out the SubCue Description field whenever there is only one Subcue (i.e. no "subcues") within a cue?
Thanks. John
John Kowtko
Sound Designer/Engineer
Redwood City, CA USA
