[Fix 11.7.1] Cue with a disabled sub-cue doesn't advance
Stuart Barry
Post by Stuart Barry » Thu Mar 22, 2018 11:54 pm
I have just downloaded 11.7.0 and found that if I have a cue containing a disabled sub-cue, when I play that cue in the main window, on completion it remains as the next cue to play and the show does not advance to the following cue.
Best wishes
Stuart
Re: Cue with a disabled sub-cue doesn't advance
Post by Mike Daniell » Sat Mar 24, 2018 12:06 pm
Working on it.
Post by Boswell » Wed Apr 11, 2018 4:45 pm
Same fault found here
Post by Mike Daniell » Wed Apr 11, 2018 7:20 pm
Fix ready. Anyone who needs it now, let me know.
Post by Boswell » Wed Apr 11, 2018 9:19 pm
Sorry Mike, another bug associated with disabling sub cues.
If the first sub cue (audio file) in a cue is disabled and the second subcue (audio file) is enabled then the "Give Visual Warning" select "Count UP whole cue" function does not work.
Swap them around so the first sub cue is enabled and it works
see attached
eg test.scs11 works
test1.scs11 fails
test.zip
(2.11 KiB) Downloaded 82 times
