Jumpy fades
Nino
Jumpy fades
Post by Nino » Wed May 24, 2017 4:44 pm
Am currently working on our latest show using 11.6.1 (x64) and have suddenly noticed a new problem. In some of my cues there appears to be a slight pause just after the cue starts. The volume sliders on *some* of the fades will move a little way, pause, then continue. I thought this was simply the screen refreshing but the audio volume jumps too.
I have gone back to a couple of previous shows and it doesn't appear to be happening on those so I don't think it's a bug in SCS rather a glitch in either this cue file or the settings for this cue file. I am using 6 channels of sound in this cue file and I don't know if that's causing the problem.
I have just tried creating the offending cues in a new file and I get a program error when selecting the audio devices:
I have also attached a diagnostic file.
Any suggestions?
Nigel
scs11diag_2017-05-24_073558.scsz.txt
(220.97 KiB) Downloaded 38 times
Nino
Re: Jumpy fades
Post by Nino » Wed May 24, 2017 5:27 pm
Mike - I also meant to add that these offending fades are only happening when running the cues live - the fades are perfectly smooth in the editor.
Re: Jumpy fades
Post by Mike Daniell » Wed May 24, 2017 5:36 pm
Nigel,
I've emailed you details of a version that should fix the memory error and hopefully will also fix the 'jumpy fades'. The memory error is the same as that reported in the bug report crashing when select midi.
