I know we've corresponded in the past about a telnet port for SCS and at the time concluded that there was little interest by the user community. Also back when we discussed this, you hadn't implemented RS232 in/out yet.
I mentioned telnet in the DMX out topic recently as I thought it would be a better mechanism than trying to have SCS inject values into a DMX packet. I've also had a discussion with a member of the LightFactory forum (a Yahoo forum) who is an SCS user who would like to drive LightFactory (LF) from SCS and vice versa. LF can already accept commands over a telnet port and the commands are ASCII just like you'd type in at LF's command prompt. LF can send commands via telnet as well, but currently only to another instance of LF.
Given that once established, telnet acts like a virtual serial port, it seems to me that adding that capability to the repertoire of SCS would be relatively easy (that's what they always say, right
I've asked the developer of LightFactory to comment on generalizing LF's send command so that a port number could be specified which would have to be a number other than the port LF uses (default is 3100). If that can be implemented, then LF will be able to send commands to SCS (or any other telnet capable application).
I think if you add telnet capability to SCS, it and LF will be a dynamite combination, especially for small venues with tight budgets (like my theatre). Also, having telnet will open up possibilities like using a PDA to control SCS, implementing a master cue controller for both lights and sound (and multimedia stuff), etc.
I'm hoping other members of this forum will weigh in on whether they would find this capability useful to them.
