Renaming "Subcue"
Suggestions for improving the SCS User Interface, to be implemented in SCS 11.9
lttton
Renaming "Subcue"
Post by lttton » Sun Jun 21, 2020 9:23 pm
What I found when training my colleagues with SCS is that there is always a mix-up with cues and subcues. The software should clearly show that each cue already contains a single subcue. The names could possibly be changed to "Trigger" and "Event" to clarify this. The appearance of the tree view in the editor could possibly be changed so that each cue / trigger contains a subcue / event.
Saludos
Re: Renaming "Subcue"
Post by Mike Daniell » Tue Jun 23, 2020 4:38 pm
I think the term "Cue'" needs to stay, but I'm open to suggestions for an alternative term for "Sub-Cue".
d_korman
Post by d_korman » Tue Jun 23, 2020 10:45 pm
"Part" (as used by some lighting consoles )?
lttton
Post by lttton » Fri Jul 03, 2020 6:30 am
Yes Mike,
i can confirm.
A Cue is a Cue… but it contains one single trigger(activation method) and multiple events (subcues)
Regards
Onno Rietveld
Post by Onno Rietveld » Mon Aug 03, 2020 2:35 am
I think that Cue must stay (Show CUE system...) but rename Sub-Cue sounds like a good idea. My suggestion is “Action”.
Regards, Onno
am@umbc.edu
Post by am@umbc.edu » Sun Sep 13, 2020 3:43 am
I agree that when teaching the software "subcue" is a tough concept for students to understand. Also, Qlab uses "group cue" and "child" which I also think is problematic to explain and maybe puts an unneeded power structure in.
I like the idea of "part" as suggested above to mimic some lighting consoles.
tocsin
Post by tocsin » Sat Nov 21, 2020 9:09 pm
Whats wrong with Subcue? It is sub the first Cue. The name fits perfect. As soon a cue is triggered by a cue befor it is a Subcue. Or do i miss here something?
lttton
Post by lttton » Sat Mar 13, 2021 2:23 am
@tocsin
With your contribution you have provided proof that the naming is unfortunate. In fact, the first cue already contains a subcue. The cue sub this cue is then already the second subcue.This is confusing and has obviously confused you too.
