MIDI and QU32
genel
MIDI and QU32
Post by genel » Sat Mar 18, 2017 11:44 am
For current production I'm controlling the mutes on 10 body pacs, and 8 mics. I'd like to add some fader control but they require something called an NRPN MIDI control that SCS doesn't know about The QU32 requires 4 of these to select and control a fader or level. It would be very nice if SCS could read a current fader setting and store it as a MIDI command. Barring that it would be nice if it just knew the 12 byte sequence and what bytes get filled in.
One other suggestion, in the current MIDI controls you have a pull down for setting the byte values. It would save a lot of mousing if the pull down opened at the same position as the last selection. Or a hot key that would enter the last value or last +1.
Re: MIDI and QU32
Post by Mike Daniell » Sat Mar 18, 2017 7:13 pm
genel wrote:One other suggestion, in the current MIDI controls you have a pull down for setting the byte values. It would save a lot of mousing if the pull down opened at the same position as the last selection. Or a hot key that would enter the last value or last +1.
I can't make the drop-own list start at a specific value other than by pre-populating the field itself with that value. However, note that with the items you mention you can just key in the decimal values - you don't need to use the mouse on the drop-down list.
