Random Access vs. "Go Next"
Posted: Tue Apr 24, 2012 3:45 am
I would like to be able to set a cue to "Standby" so it is ready to "GO" even although it is already set-up as a hotkey cue.
A scenario would be where I am doing Youth events, quite interactive. I have a bunch of SFX and stings on hotkeys that I can fire off spontaneously depending on content, but also might want to get something ready to trigger without having to look for it on the keyboard. I'm already trying to follow a bunch of lairy presenters with shoddy mic technique round the room!
My follow-up thoughts to this are as follows:
[*]I suppose I could make 2 cues for each sound, but would rather not have to do this as I am often doing stuff on the fly, and it could become a bit messy.
[*]I see on Beta 11 there are GoToQs which would simplify that a bit. - Have I missed something, can I do that on 10?
I can't see that it would cause any problems to manually click to make ready a hotkey cue (or cursor up/down to it), In fact I can't see why you wouldn't want to be able to select it as a next, the cue would still be skipped in the cue list in 'normal' linear operation, notwithstanding that you would be moving to another place in your show if you did manually select it... but that's the point.
