Image Cues (fix in 10.6.2)
Posted: Thu Oct 15, 2009 10:04 am
Hi Mike et al . . . . I think this issue may have cropped up before but I couldn’t find it again.
I’m involved in an ongoing music production which involves multi-track audio/MIDI Cues, video Cues and image Cues. The main points of this post are regarding the image cues and the resultant main screen display.
Following certain audio Cues I have programmed a still image Cue activated by ‘Auto Start’ and set to ‘Continuous Play’. This Cue is then followed by several audio Cues, all manually started. Because the image Cue is still “playing”, when I get to the audio Cue at the bottom of the screen I can’t see any more Cues.
Unless I am missing some way of overcoming this I have a couple of suggestions to make.
1) Can the main screen continue to scroll in the normal way? The image Cue will then either be stopped by a subsequent ‘manual’ or ‘auto’ Cue/Sub-Cue.
2) If a Cue is to be activated by ‘Auto Start’ could there be another optional checkbox under ‘Cue Properties’ called ‘Hide’ which, although ‘Enabled’, prevents the Cue from being displayed on the main screen. The purpose of this suggestion is to avoid unnecessary clutter. It may seem a bit obvious but you can always see whether or not there is an image Cue being displayed by looking at the theatre screen.
Cheers . . . . . Martin
