Extra field - Script page number
john-tapas
Post by john-tapas » Fri Jan 02, 2009 10:05 am
A simple addition that I think would save time, in particular at rehearsals, would be another column on the cue list for the Script Page Number
When rehearsals start, using cue numbers is frequently a lost cause because;-
1 Que numbers get changed as additions are made, pages are set in stone.
2 Cast and Director are all talking script page numbers
Re: Extra field - Script page number
Post by Boswell » Fri Jan 02, 2009 7:54 pm
I put page numbers at the start of the description field, eg P4 Fade Car, Betty ON or in the 'When required' field
but I agree it could be useful as long you could select not to display it if required.
Post by Mike Daniell » Sat Jan 03, 2009 10:25 am
Inserting the page number at the start of the Description, as per Boswell's suggestion, is what I always do and have found this sufficient.
kharney
Post by kharney » Wed Jan 21, 2009 6:29 am
I put the page number in the field " when required"
AndyT
Post by AndyT » Wed Jan 28, 2009 6:26 am
HI
I have found that with Mikes flexible Cue Numbering, I use the Cue number field to hold both the page number and then a letter designating that cue, i.e. 21a page 21 first cue. I suppose this would get more difficult when there are more than 26 cues to a page, but with our productions there is no chance on that happening, mores the pity :?
Andy Terry
Manifest Theatre - Manningtree - UK
