1.) The cue description - having moved to the top of the screen from the bottom - is now cut off by the MASTER volume slider. This requires designers to keep cue description & "when needed" entries shorter. I'd like to see that field dropped back down to the bottom of the screen where there is more room.
2.) If the Escape key is used during a tech-rehearsal, a hibernating playlist (like preshow or intermission music) has to be manually restarted. Is there a way to make a hibernating cue exempt from the STOP EVERYTHING function?
Hibernating cues & Escape + Cue Description Field
Re: Hibernating cues & Escape + Cue Description Field
How about I provide a Display Option to increase the height of the Next Manual Cue field to display 2 lines? btw, if you choose not to display the Master Fader then (in the next release) the Next Manual Cue field will expand to use that space.escrge wrote:1.) The cue description - having moved to the top of the screen from the bottom - is now cut off by the MASTER volume slider. This requires designers to keep cue description & "when needed" entries shorter. I'd like to see that field dropped back down to the bottom of the screen where there is more room.
That's a bug - SCS should have left the cue hibernating. I'll fix that in the next release.escrge wrote:2.) If the Escape key is used during a tech-rehearsal, a hibernating playlist (like preshow or intermission music) has to be manually restarted. Is there a way to make a hibernating cue exempt from the STOP EVERYTHING function?
Could it be possible to have only the value of the Master Fader, not the fader-"picture" displayed on that position?Mike Daniell wrote:btw, if you choose not to display the Master Fader then (in the next release) the Next Manual Cue field will expand to use that space.
Regards...
...Maik
...Maik
