[Resolved] Fade all not respecting fade times
Posted: Thu Sep 26, 2024 8:34 pm
Is this how it should work?
When I Fade All either using an SFR cue or by using Shift+Esc it seems to fade almost straight away. I use this at the end and the one remaining cue has a 5 second fade out. Even tried putting 5 second overide in the SFR cue and it still seems to fade out - it might be using the default time whioch is 2 seconds.
A fade of the specific cue works fine and fades out in the 5 seconds.
I can see reason for Fade All using the default - Ie if you had something like a 20 minute fade. But just wondering if that's the way it's meant to work or not.
Ohh and I can see a workaround - using and SFR cue - Fade out all earlier cues. Seems to work.
